Old 02-03-2015, 01:36 PM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Pure stock and cam lobe design?????
Originally Posted by Bernhard View Post
How do the IHRA measure spring pressure, is it at the factory installed height ?
If they do it like NHRA did when they were still checking, they willl measure the installed height of the valve spring on your engine when the spring is removed and that is the height they will use to check the pressure of the valve spring. The specs will give a seat pressure and a pressure at a designated height and the inspector will use the difference to check the spring rate.
Example: Common SBC spring was spec'd at 84 lbs on the seat @ 1.700" and 206 lbs open pressure @1.250". That's .450" difference between the seat and the open spec. The tech measures the installed height on your engine of the spring he removes and finds that measurement to be 1.765". He uses a micrometer type instrument on a valve spring pressure checker to find out the pressure of your spring at 1.765". If it is 84 lbs or less, you're okay. Then he compresses the spring an additional .450" and your spring should be less than 206 lbs.
They are concerned that you are not exceeeding the pressure specifications, not the factory specified installed height.
