Old 01-31-2015, 10:14 PM   #17
Ed Wright
Ed Wright's Avatar
Default Re: New Indexs are up
Jeff, if you could just point out where I ever claimed to be fast, I would appreciate it. Really would. Ricky Decker and Jeff Dona are very fast with the same combo I run. I piece my stuff together best I can, with what I can afford. I do the best I can. When a Challenger like yours, with the same engine you run (just much faster) running Ricky for class (SS/IA) at Indy 2013 starts whopping the throttle, playing with Decker from the 1/8th mile to the end. That tells most intelligent people that engine (same engine you run) is badley under-rated. Like myself, maybe your just not as fast as you should be? Might want to hire Sonny Stancil and James Caro to help you out. Their stuff is fast. Unlike you, I can't afford to hire help, so I will just have to continue to be slow.
Many (including myself) believe factory race engines (at least the heads, etc) like you have, don't belong in the same classes with production cars that used pump gas and passed emissions testing, got good gas mileage, etc, etc.
So, now you are whining about no more easy class wins & heads-ups. Your going to have to try to outrun other DPs.
Ed Wright 4156 SS/JA
