Liked 4 Times in 1 Post
I have an 88 Camaro J/SA TPI 230/264HP 350 for those of you who may recall it's the late great Jim Harringtons old car. I am trying to replace the valve springs and I have no idea what I'm looking for could anyone tell me what springs I need for this motor size, type, brand, part number whatever.
The car has developed a miss right at the shift points and I've checked everything I can possibly think of and this is the only thing I can come up with being the problem. Thank You in advance, Mark Young |
Liked 56 Times in 27 Posts
Marco,
Call Bud Rowe @ 252-633-4084 , he can help you out ... I think that's one of his old cars anyway ?? LOL
Dave Ribeiro 1033 STK |
Thanks Dave I did already he and Brian are out of town today and I was trying to get something ordered today if I could.
Liked 13 Times in 4 Posts
Here is thread from last year about the PAC1409X springs. We abuse them regularly in our Chevy II stocker!
http://classracer.com/classforum/sho...d.php?p=421373
Joe Schaechter 3168 STK |
Liked 1,470 Times in 308 Posts
Mark, we have the same combo and went with Comp. Cams conical
springs. Give Tim Cole @ CompCams a call and he will look after you well. J.R. |
Marco,
Feel free to call us (PAC) at 866-799-9417 ask for Matt. I will tell you the same thing Jim said. It's a tried and true combo. |
Liked 5 Times in 4 Posts
Does it have a miss in high gear? What RPM do you shift at? I don't believe the tune port likes a lot of RPM's like the carb engines do.
Shift it at 58 and 6000 and once the rpm gets back up to around 6 it returns
almost sounds like a fouled plug when it does it |
Turbo Buick PM sent
Liked 269 Times in 99 Posts
Marco
Know a little bit of the history of that car. Is your engine flat top or dish piston with 083 head? The HP you provide would be for the dish piston I believe. Your high RPM miss can be the valve springs but the only real way to know is to take off a couple and check open and seat pressure. The hot ticket right now is conical springs, they have some good qualities but unless this is a max effort conventional springs at lower cost still go down the track. Check evertything in your ignition. Don't assume because it new it's good. One time I was having problem with the car slowing, after fixing it was slowing up again! The distributor was not tightened completely when syncing with ECU trying to find the first problem. Look for dumb stuff. Look over your fuel and timing maps to be sure nothing was changed by mistake; look over your set up in the software to be sure everything is as it should. Ask me why I know this......... Make sure you have fuel pressure and volume, it will miss upstairs if it's real lean. If you data log Air Fuel Ratio it will indicate, if you don't you should. Check the plugs too.
