Old 01-15-2015, 05:35 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1968-70 396 427 & 454 Blocks & Parts
1968 427 4 bolt standard bore block casting 3916321 dated L-8-7 stamped T0219IR 18S412651 which is a 435HP tripower block $2500.
1968 3919840 square port heads complete and were redone both dated C-18-8
$1650.
1970 402-375HP 4 bolt block standard bore casting number 3969854 dated J-3-9 stamped T1007CKO 10W155101. I have the 6223 steel cross drilled standard crankshaft, oil pan and 8 inch timing cover $2500.
3964291 square port heads bare dated B-4-71 & B-5-71 $750.
1969 3933163 factory aluminum square port intake dated 10-30-68 with thermostat housing all cleaned up $450.
1970 3964291 square port heads complete dated I-12-9 & I-11-9 $1250.
1970 Holley list #4492 complete and has original metering blocks with choke still intact dated 043 which is 1970 April 3rd week $750.
Parts can be shipped if you cannot pick them up. Any questions I can be reached at 330-770-2517. Pictures can be provided with an email address.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
