Old 01-09-2015, 11:04 PM   #2
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Default Re: WTB, 3.00 gears for 8.8 Ford
I'm guessing you mean the different rear pinion bearing used in Mustangs the last few years. The bearing has bigger diameter but shorter rollers at a different angle. Still the same bore in the case and no difference in the pinion, so you can switch from one bearing type to the other.
As for 3.00, I'm not aware of any ratio between 2.73 and 3.08, ever.
K Danner STK 468
kdanner is offline   Reply With Quote
Search this Thread:
Advanced Search
