Old 01-03-2015, 12:28 AM   #1
Bob Lambeck
Default Re: Items allowed by NHRA over the years
flat towed to indy with tow hubs steve burns came to me at the winter nationals and said what would think if some one made a race gas nhra would except that would be better than white pump. I said yes how much? about a dollar a gal. I said no . white pump was 39.9 a gal and 280 Sunoco was about the same if you could brake the seal. being a big guy I went to Jack hart and farmer and said why not weigh the car with the driver in wouldn't it save time at the scales they said how much should we add for the driver I said national aveage for a man is 170. that is how that number came about. I have had a lot of good times racing took my wife of 50 years last week on our firsr date to the drags was talking racing the whole nite she should have figured it out but didn't Won my class in 1963 winter nationals tore down got out at 3 am towed home with a rope no racing sunday.
Bob Lambeck is offline   Reply With Quote
Old 01-03-2015, 01:21 AM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Bob,
Maybe you contact NHRA again and get the driver weight adjusted for us full figured guys?????????????????
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 01-03-2015, 01:50 AM   #3
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
Yeah, I started out Towing my '69 GTO to the tracks with a '68 4-door Caddy. It had a 472 engine with plenty of power for towing and a huge trunk for tools and stuff.
Two tracks we ran, still had a flagman--no lights or timers. And the tracks were airstrips that were still in use. When a plane needed to land, they would buzz us and we would clear the track til the plane parked, then go back to racing.
In '73 we had to run hard street legal tires. I ran M&H tires, but they were hard street tires.
Then in '74 they allowed some street legal slicks with a couple of grooves in 'em. They were similar to the drag radials they have today. They knocked a half sec off my ET instantly.
Then in '75 we could run headers and 9" slicks. All this took place in north Louisiana. Don't know what they were doing anywhere else.
Then in '76 and '77 most of the smaller tracks in this area switched to bracket racing.
ID:	26753   Click image for larger version
Name:	100_1880 - Copy.JPG
ID:	26754   Click image for larger version
Old 01-03-2015, 06:14 AM   #4
Kenny Bomar
Liked 425 Times in 51 Posts
How about when we had to use 7" slicks they would put a measuring tape on them make sure only 7". We had to put the car on jack stands as the wheel is spinning using a body file and trim the tire down to make sure 7". Kinda dangerous when you think back on it but that was low on the dangerous scale of a lot of things we did back then! Hey that would be a good Post "wild and woolly things we did to drag race!
Kenny Bomar is offline   Reply With Quote
Old 01-03-2015, 09:08 AM   #5
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
I remember we would use the line lock and "spin" start the car. That lasted until someone left divits on the line. Finally Marv Ripes got many around here to use a "Stall" converter.
Old 01-03-2015, 11:13 AM   #6
Dick Butler
Liked 32 Times in 19 Posts
Original Class wt breaks was an interesting story. Some went to .5 lb because neighbors or friends didn't want to be in same classes. then it went to even lb and you couldn't add or subtract wt. Shipping wt was it....Everyone used certain bodies to make class better. Bus coupe, 9 pass wagons, Sedan delivery. Sure there were special fords and Pontiacs . Allowing wt adjustment to top of class and weighing with driver were two REAL improvements. 170 lb driver wt is unrealistic today...Needs to be 190-200. Still being able to adjust car makes up for this.
Ball joint lift kits were dangerous Had one A arm tearing at a bolt hole and luckily noticed car leaning in time to replace it not the whole car.
Only new cars in Stock and moving all old to SS was a hard rule. Now the old cars can return but costs and newer tech makes it unlikely.
Teching in the lanes AFTER parking in the pits is Great. I sat in line in the entrance to Indy my first year for one night, next day and second night to get to tech in round track.
Old 01-03-2015, 01:24 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
The car was weighed without the driver and with 5 gals of gas.
We set a record and were asked to drain the fuel tank after the backup run. The car was not much over the shipping wt. More than 5 gals came out so the back up run was disallowed.
We added a spare tire but time ran out and we did not get that record that day.
The driver on both runs was probably over 200lbs....
Many rules from the past really needed changing....that was one...
And the 7" tire rule was dangerous.....and definitely needed changing well before bigger tires were allowed.
Big Block Stockers were running 120mph on 7" tires with narrow rims....
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 01-03-2015, 02:24 PM   #8
Jeff Teuton
Liked 325 Times in 50 Posts
Recent stuff is light seats and roller rockers, just when did NHRA create SS from Stock. And the removed back seats, are outside mirrors required? I think that has gone. Way back even seat belts weren't needed let alone a helmet. There are ton's of things. I see memories are being taxed. Please post your bit of history.
Jeff Teuton 4022 STK
