Old 01-02-2015, 07:20 AM   #1
John Langer
Liked 3 Times in 1 Post
Default garage sale
- Moroso split billet rail aluminum Pontiac Langer pan, wet sump, BOP belt drive front, rails bent from giant wheel stand, still seals to block, used, $350
- Moroso aluminum wet sump Pontiac Langer pan w oil pump and pick-up, BOP belt drive front, used, $500
- GRP aluminum rods, set of 8 w 50 runs, 2.100 rod, .990 pin, 6.800 long (i forget) used, $200
- Comp cams push rods set of 16, 9.350" long .080 wall #7979 hi-tech chromoly, heat-treated 3/8", used ($160 new) $80
- fluidampr Pontiac balancer, used, $250
- moroso 2 groove aluminum crank pulley 4" OD machined to fit above balancer, outer groove is dented, used, $30
- HVH super sucker SS4500-1.1 plastic 1" for 4500 dominator carb 2.125", used, $75
- Wilson Manifolds 4500 tapered carb spacer 1" tall 2.100 bore #024510, new, $140
- Mr gasket 4150 2" aluminum carb spacer, used, $20
- (2) Fram PH5 oil filters, new $10 pair
- Barry Grant BG280 fuel pump, used, $150
- (3) Barry grant 4-port pressure regulator brackets $10 ea
- 5-gallon poly fuel cell w -8 outlet and missing other outlet fitting, -8 retuen missing vent fitting, used, $50
- Moroso aluminum 727 proflite trans pan w drain plugs, bottom side dinged up from wheel stands, used, $80
- B&M pro ratchet shifter cover, aluminum for 3-4 speed auto trans, new, $40
- Hurst quarter stick 3-speed forward pattern w cable, no knob, used $120
- (1) Moser pinion support w bearing, large, used $75 ea
- Autometer pro tech series playback box, used, $50
- Simpson cam-lock 5 way harness, black, great shape, out of date, $75
- Front windshield fits 67-69 firebird/camaro $100
- Back window glass fits 67-69 firebird/camaro $100
- Rear quarter glass right and left fits 67-69 firebird/camaro $50 ea
- rear quarter regulators right and left fits 67-69 firebird/camaro $50 ea
- 1969 firebird center console auto burr wood w blue sides $150
Parts are located in Phila PA, prices do not include shipping
John Langer is offline   Reply With Quote
Search this Thread:
Advanced Search
