Old 12-30-2014, 11:26 PM   #1
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: wideband air/fuel meter
Originally Posted by boostedf22c View Post
I would recommend the AEM as well. It's priced well and offers much more than just a gauge readout.
Originally Posted by ALMACK View Post
I use the AEM brand "Wideband Failsafe" a/f gauge.
In addition to recording the a/f, it logs manifold pressure and samples 20 times per second.
I like the ability to program it to activate the failsafe function if the afr gets too high.
How well do you like these? I've got a pyrometer in my car. But it warms up too slow. Does the AEM (or others for that matter) use a 3 or 4 wire sensor ?
Originally Posted by vic guilmino View Post
i hope it out this year i have the pistons in the block
LIKE
Dave Noll, EF/S ,?/SA 6526
Old 12-31-2014, 12:22 AM   #2
boostedf22c
boostedf22c's Avatar
LIKE
The AEM uses the Bosch wideband sensor. It's a 6 wire sensor. It comes with all the wiring and harnesses you need as well as weld bung.
http://aemelectronics.com/files/inst...fe%20Gauge.pdf
In my opinion it's the best looking gauge as well. The readout is really nice and it's very configurable.
http://www.aemelectronics.com/?q=pro...failsafe-gauge
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 12-31-2014, 01:09 AM   #3
Dave Noll
Dave Noll's Avatar
OK, newb asking, can the gauge & sensor be used together without the datalogger ?
Old 12-31-2014, 01:15 AM   #4
boostedf22c
Yes.
Carey Bales
316D DD/AT
www.racetactics.net
Old 01-01-2015, 01:22 AM   #5
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
As Cody posted above, yes it could be used without the data logger.
On the AEM Failsafe, the data logger is built into the gauge.
On my car, I have a toggle switch that turns on the +12V to the Failsafe, and about 4 seconds later it starts logging.
Then after I pass the finish line, I turn the switch off.
Then when I get to the pits I download the run.
It's a nice piece of equipment, and because I run an EFI system with alot of boost and only 4 injectors, I need a device like that for extra insurance.
Here is a pic of my setup within arm's reach while belted up.
This is what the download will look like on the computer :
(It plots one of those yellow blocks 20 times per second)
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
