Old 12-29-2014, 01:53 PM   #1
Dick Butler
Liked 32 Times in 19 Posts
Default Fwd chassis versus RWD Et
When it comes to advantages or disadvantages, how much does it appear using a FWD conversion is better than older RWD chassis. I have heard some report as much as .15 improvement when they place drive train in FWD from their older RWD cars.... Any input?
Old 12-29-2014, 04:42 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Fwd chassis versus RWD Et
Kinda depends. As for GM cars, if you don't need to be under 2900/3000 lbs it would be hard to beat a '93/'02 Camaro/Firebird at that weight. 101" wheel base, with the engine set back. Half the engine is under the windshield & dash. Pete Peery told me that my driveshaft is like 8" shorter than his little GT car. You can run smaller tires with more air. When it gets hot, and my friends with the "jellybean" fwd GT cars start spinning & talking about the track going away, my car can't tell the difference. Likely not as easy a car to work on, however.
The reason you see so many running GT classes with carbs, ain't because they came from the factory with fuel injection. :-)
Ed Wright 4156 SS/JA
Old 12-29-2014, 05:47 PM   #3
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
This is another one of those questions that depends on who you ask. Jimmy Boburka had a VERY nice, well beat to death F-Body Camaro. He built a really nice Cobalt and did exactly as you mentioned . Everything he could use he did. Motor, Trans, 3rd member, ...everything. Of course the headers had to be changed. He then headed to a track that he new like the back of his hand. He told us it was 7 to 8 faster.
But ,I've had one good friend swear that it is not nearly that much.. And they also have had both platforms.
Jeff Niceswanger 3740 SS
Old 12-29-2014, 05:54 PM   #4
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
Five to seven
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 12-29-2014, 06:11 PM   #5
Ed Wright
Ed Wright's Avatar
Hard to think where it would come from, if we are talking about a 4th gen. Especially when the track goes away.
Old 12-29-2014, 06:24 PM   #6
Jeff Niceswanger
Originally Posted by Sean Cour View Post
Five to seven
You should know !
Old 12-29-2014, 06:37 PM   #7
Ed Wright
Ed Wright's Avatar
Gotta wonder where it is. A 3rd gen, I could understand.
