Old 12-20-2014, 09:02 AM   #1
Liked 16,560 Times in 1,523 Posts
Default ATI COPO Superchager Video Update
The first video that most you have already seen is JC Beattie in his ATI COPO Camaro under the hood. As you can see the tensioner goes nuts. The Second video is JC with an upgraded tensioner now running a 3 speed trans. JC tells me it help a bit, what do you guys think.
Old 12-20-2014, 09:32 AM   #2
D.Johns
D.Johns's Avatar
Liked 18 Times in 6 Posts
Default Re: ATI COPO Superchager Video Update
Looks like the belt has less distortion on lower pulley with the new set-up. Three speed helped out a bunch with more mechanical leverage.
Still to many idler pulleys on these supercharged cars.(SCJ+COPO)
2014 Cobra Jet FS/XX #3345 STK/SS
Like us on http://www.facebook.com/pages/Daniel...25886327426822
D.Johns is offline   Reply With Quote
Old 12-20-2014, 01:04 PM   #3
Dan Wilson
Maybe they need to try this pulley setup.
Dan Wilson, STK3171, K/SA
Dan Wilson is offline   Reply With Quote
Old 12-20-2014, 02:28 PM   #4
D.Johns
D.Johns's Avatar
The SCJ uses 6 idler pulleys and 2 different designs. The 2013 used 1 single belt to run everything. The redesigned one used 2 belts and was a better design. Still to many idler pulleys and too long of belt for both for my liking.
Old 12-21-2014, 11:27 AM   #5
FINESPLINE
FINESPLINE's Avatar
Definitely a tensioner with a beefier casting and seems to control the pulley windup better. I think everyone with a 2 step should watch the videos as they ( not all ) might try modifying their routine in staging ( time wise ) with the 2 step. It sure does slap that pulley around and that pulley is just a window to what is going on inside the motor. Just my observance .
FINESPLINE is offline   Reply With Quote
Old 12-21-2014, 12:33 PM   #6
Alan Nyhus
Liked 799 Times in 236 Posts
I try to imagine what the crank and cam bearings are going through when on a Two Step.....
"That'll never work....."
Old 12-21-2014, 12:57 PM   #7
Liked 1,831 Times in 415 Posts
According to David Reher, it is the valvetrain that gets trashed on the two step.
Old 12-21-2014, 01:22 PM   #8
D.Johns
D.Johns's Avatar
http://rehermorrison.com/tech-talk-7...g-your-engine/
I'm always trying to pull information from guys who have "been there, done that, got the T-shirt"
Old 01-10-2015, 06:41 PM   #9
Midnite Magic
OEM Tensioner off something else?
Midnite Magic is offline   Reply With Quote
