The HP penalty for a replacement head doesn't change the classification of a car; it is added after the fact. For example: A 1969 Camaro 427/425. You divide the shipping weight by the 425 to get the class; Class weight x 425 + 170. You add the 10 hp after. SO, in A/SA, you add 80 pounds (8 pound class, 10 hp penalty) after the fact.
The shipping weight never changes; it is what it is. If the shipping weight is 3,369 pounds, you will always use that number; divided by the HP (with OEM head) of the motor desired. You then add the hp penalty weight after. If a car falls into, say, GT/EA. 10 pound class. If an aftermarket head is permitted, with a 5 hp penalty, the aftermarket head version weighs 50 pounds more than a car with the same motor and an OEM head. If I am wrong, someone can correct me, but I believe that is the way it works.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
#2 | |
Liked 237 Times in 126 Posts
Weight: 3369 Stock: 302/220 SS w/replacment heads: 302/230 HP added: 10 3369/220 = 15.31 GT/MA If this is right and M is the last class, where does the extra 100 lbs for the HP hit go? does my car need to weigh 3469? Dale EDIT: Now that I have them working right, I ran my build through Dwight's Tools and came up with GT/KA through GT/MA depending on weight up or down. That makes more sense to me than trying to decipher the fine points of the rule book's English. So....never mind.... Last edited by FireSale; 12-02-2014 at 05:38 PM. |
#3 | |
yes 3469, but I do believe we are supposed to round to the nearest 10....so 3470
Dion Hildebrandt 6009 STK H/SA |
#4 | |
Dale |
Liked 46 Times in 10 Posts
Fire Sale,
If you car is a convertible then 3369 is correct. If not then 3267 is the shipping weight to use. With the engine rated at 335 the your non convertible would run C @3185 or D @ 3350 or E @ 3520. A convertible would run C @ 3285, D @ 3350, E @ 3520 or F @ 3685. These weight are class minimums. The convertible can't get to the top of C and would have to run 100 heavy for the class.
Ryck Campbell NHRA Technical Specialist |
#6 | |
As I understand it, GT is like building a car that never came off the production line even though it has the right brand parts in it. So a weight is assigned to the body and the class is determined by the engine factor. It could have been the actual weight of the body used (68 Mustang coupe) or an average 68 Mustang weight, but someone decided on using the heaviest one available. I guess. Dale |
Liked 780 Times in 194 Posts
The heaviest coupe weight is 3241, which is what you would use for calculation. You would not use the convertible shipping weight for a coupe body.
