Old 12-02-2014, 01:59 PM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: GT Classification Worksheet
A question that has come up in my PMs about this is that the Stock Car Classification Guide contains shipping weights and they don't match the weights you get if you use the formula contained in the GT weight rule.
My heaviest gas engine version of the 68 Mustang is the 428 convertible auto at 3369 lbs. If I use the factor times HP formula mentioned in the rule (8.87 X 335) I get 2971. If I use the Super Stock with replacement heads HP (8.87 X 383) I get 3397 lbs. Which of these should be used for the shipping weight?
Dale
Old 12-02-2014, 02:13 PM   #2
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
The HP penalty for a replacement head doesn't change the classification of a car; it is added after the fact. For example: A 1969 Camaro 427/425. You divide the shipping weight by the 425 to get the class; Class weight x 425 + 170. You add the 10 hp after. SO, in A/SA, you add 80 pounds (8 pound class, 10 hp penalty) after the fact.
The shipping weight never changes; it is what it is. If the shipping weight is 3,369 pounds, you will always use that number; divided by the HP (with OEM head) of the motor desired. You then add the hp penalty weight after. If a car falls into, say, GT/EA. 10 pound class. If an aftermarket head is permitted, with a 5 hp penalty, the aftermarket head version weighs 50 pounds more than a car with the same motor and an OEM head.
If I am wrong, someone can correct me, but I believe that is the way it works.
Old 12-02-2014, 04:24 PM   #3
FireSale
FireSale's Avatar
So:
Weight: 3369
Stock: 302/220
SS w/replacment heads: 302/230
HP added: 10
3369/220 = 15.31 GT/MA
If this is right and M is the last class, where does the extra 100 lbs for the HP hit go? does my car need to weigh 3469?
Dale
EDIT: Now that I have them working right, I ran my build through Dwight's Tools and came up with GT/KA through GT/MA depending on weight up or down. That makes more sense to me than trying to decipher the fine points of the rule book's English.
So....never mind....
Old 12-02-2014, 05:25 PM   #4
Dion Hildebrandt
Dion Hildebrandt's Avatar
Originally Posted by FireSale View Post
So:
Weight: 3369
Stock: 302/220
HP added: 10
Dale
Dale
yes 3469, but I do believe we are supposed to round to the nearest 10....so 3470
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 12-02-2014, 08:08 PM   #5
FireSale
FireSale's Avatar
Shipping weight is 599 lbs lighter than that for the stock version of the 302 coupe. What was I thinking when I bought aluminum heads??? At least I won't have to worry about the weight of my mild steel cage any more...
Dale
Old 12-02-2014, 08:30 PM   #6
Ryck Campbell
Ryck Campbell's Avatar
Liked 46 Times in 10 Posts
Fire Sale,
If you car is a convertible then 3369 is correct. If not then 3267 is the shipping weight to use. With the engine rated at 335 the your non convertible would run C @3185 or D @ 3350 or E @ 3520. A convertible would run C @ 3285, D @ 3350, E @ 3520 or F @ 3685. These weight are class minimums. The convertible can't get to the top of C and would have to run 100 heavy for the class.
Ryck Campbell
NHRA Technical Specialist
Ryck Campbell is offline   Reply With Quote
Old 12-02-2014, 09:14 PM   #7
FireSale
FireSale's Avatar
Originally Posted by Ryck Campbell View Post
Fire Sale,
It's a GT build. A 68 Mustang coupe using the engine specs of the 302/230 found in the 68 Cougar. The rules say to use the heaviest gas engine body as the shipping weight, which is the 68 convertible 428/335 . That's where the 3369 comes from. The engine is rated at 220 with 10 added for the AFR 1399 heads.
As I understand it, GT is like building a car that never came off the production line even though it has the right brand parts in it. So a weight is assigned to the body and the class is determined by the engine factor. It could have been the actual weight of the body used (68 Mustang coupe) or an average 68 Mustang weight, but someone decided on using the heaviest one available. I guess.
Dale
