#51 |
Liked 7 Times in 4 Posts
Try removing the driveline and grease the splines on the yoke and make a hit .
Bob Aceves, 746 E/SA A&M motorsports |
#52 |
Did this problem get solved?
67 Ford Fairlane F/SA 749 |
#53 |
I was told if you shut the car off and coast at the end of the run there is a lot of parts in the trans that arn't getting oiled since the the pump isn't being turned.
#54 |
Liked 132 Times in 27 Posts
Dan,
If the bad heim doesn't fix it check the axles for runout. I had a drivers side axle bent that caused a bad vibration in the Mustang. Changed alot of stuff before I found it. Chucked both axles up in a lathe and could see it before I put the dial indicator on it. Good luck. rod |
#55 |
Liked 499 Times in 236 Posts
Hope you found the problem Dan and got it resolved by the way hows the new COPO Camaro doin ?
Jake Biermann |
