Liked 10 Times in 4 Posts
SBC CNC Bowtie Block: 4.030 Bore, 55mm babbit cam bearings, 4-bolt billet caps, Jesel Key-lifter bushings, all machine work done by Weston Machine, Fresh hone $2,500 SOLD
Bryant Crankshaft: 2.980" Stroke, Honda rod journals, 283 Main journals, MINT condition $1,600 . Bullet Cam: 55mm, record setting SS/CS camshaft $250 Pistons, Rods, Pins: BME 4.029 Bore, Rebco Lightened, .7mm ring grooves. GRP Aluminum 6.00" Long, Honda journal, .927 Pin, PPP Casidium coated Titanium wrist Pins .927" diameter x 2.484" Long $500 Calico Coated Bearings: 350 Block journal to 283 crank journal p/n MS1110H $150 Package deal for everything ABOVE to build SS/CS legal shortblock:. $4,600.00 Jesel Keyway Lifters: .937" diameter, .850" diameter wheel, all +.150" Offset $500 SOLD Dart Iron SBC Castings: SS/CS Approved, brand new in the box set of heads ready for porting. Special ordered with Ductile Iron Exhaust seats, and 5/16" guides $800 for the pair BRE 750cfm SS/BS-CS Legal 4150 Holley Carb $750 Richmond 9" Ford Gear Sets, Small Pinion on each: 6.20 Pro Gear $100 SOLD 6.33 NEW $150 6.50 Pro, 2 Runs $100 SOLD See RacingJunk Ad #182325386 for photos Call Randy @ 612.306.5387 with any questions Last edited by MANSRACING; 12-09-2014 at 07:10 PM. Reason: sold some parts,entered wrong info |
