Old 11-11-2014, 12:25 PM   #1
JEFF
Default Blocks, cranks, heads, stocker part-Cheap-Mopar, Chevy, Ford
Cleaning out my garage. All parts will be available for one week only, must be paid for by Tuesday, November 18th, if not then will be sold to a waiting core supplier. Please call Jeff at (330) 456-3045 with any questions or if you need any pictures emailed. I would prefer phone calls over emails when possible. Please leave a voicemail if I don't answer with a return number and parts your interested in and I will call back. Parts are in Canton, Ohio.
Blocks:
1969 302 Ford. Block #C90E-6015-C. OH581395. OE07C. Block is standard bore, has been baked/tumbled and magnafluxed. One cylinder has a crack and needs sleeved.
$100.00 plus shipping
1970 383 Chrysler. Block #2468130-9, date code 4-30-70. Block has not had anything done to it, it is standard bore. It can be cleaned and magnafluxed before purchase if desired by a reputable local shop that I will take care of for no extra charge besides the $120.00 that the shop charges. Cast crankshaft, stock rods and 906 heads are all with this if desired. $250.00 takes everything or $100.00 for the block only.
Heads:
1970 429/460 Ford DOVE-C. Heads appear virgin. They have been cleaned and magnafluxed. There are no cracks, comes with valves and springs.
$100.00 pair.
1978 351 Windsor heads D80E-AB. Heads have been cleaned and magnafluxed. They have no cracks and appear virgin.
1969 Ford 302 heads. C90E. Heads are bare and need total rebuild. $40.00 pair as is or I can have cleaned and magnafluxed for a total of $80.00 for the pair with cores.
1978 Ford 302 heads. D8OE. Heads are complete, uncleaned and virgin. $40.00 pair as is or $100.00 for the pair if I have disassemble, cleaned and magnafluxed.
1968 327 bare head. C 15 8 date, 291 casting #. Head is bare, has been cleaned and magnafluxed, no cracks. Head has been ported and has pinned rocker studs. $40.00
1968 327 Chevy 040 castings. 3947040, date D 5 8, T heads. Heads are cleaned and magnafluxed, no cracks. Heads have some decent looking port work done intake and exhaust, have pinned rocker studs. $100.00 pair.
1968 327 Chevy 040 castings. 3847040, date D 8 8. Heads are bare, appear virgin except look like they have been milled. $40.00 for the pair or $80.00 for the pair if I have them cleaned and magnafluxed.
1977 350 Chevy 882 heads. 333882, date A 20 7. Heads have been cleaned and magnafluxed, no cracks and appear virgin. $60.00 pair.
1978 350 Chevy 882 heads. 333882, date D 7 8. Heads have been cleaned and magnafluxed, no cracks and appear virgin. $60.00 pair.
1977/78 Chevy 882 head. 333882, date F 4 7. Head has been cleaned and magnafluxed, no cracks. Head has been milled for screw in studs and guideplates, has been mildly ported and has been opened up for 2.02x1.60 valves. $50.00 for single.
305 Chevy heads. 4014416 casting #, date H 0 6. Heads have been cleaned and magnafluxed, no cracks and appear virgin. $80.00 pair.
1976 305 Chevy heads. 354434, date D 6 76. Heads are bare, have been cleaned and magnafluxed, no cracks and appear virgin. $80.00 pair.
1985 305 Chevy heads. 601 casting, date H 28 4. Heads are bare, have been cleaned and magnafluxed, no cracks and appear virgin. $80.00 pair.
1971/1972 BB Chevy rectangular port 026 casting head. This is a single head that has been cleaned and magnafluxed, no cracks. $40.00 for the head. This head was very rusty, has pitts everywhere, and will need COMPLETELY redone to be usuable.
427 Chevy truck heads. 3933148, date C 14 9. Heads are bare, have been cleaned and magnafluxed, no cracks and appear virgin. $60.00 pair.
Crankshafts:
305/350 Chevy 442 cast crank cores. All are standard or .010 no spun bearings, 2 piece rear main seals. $40.00 each or $180.00 for all 6 that I have.
1986 305 Chevy one piece rear seal cast core, standard, no spun bearings $40.00
327 Chevy steel 4577 small journal crank. Crank has a fresh, never run .010 main/.040 rod grind. Crank has extra .001 clearance cut for racing applications only. Crank has had front snout drilled and tapped for bolt. Run it as is or maybe have it turned down for Honda rods? $150.00
SCAT 383 large journal 3.750 cast stroker crank. Used standard shaft. Should have polished or cut .010. $75.00
396 Chevy steel 6223 crank. Crank has a spun rod journal, needs to go .030/.040 or possible weld. Cleaned and magnafluxed, no cracks. $50.00
396 Chevy cast crank. Crank has a spun rod journal, needs to go .020/.030 or possible weld. Cleaned and magnafluxed, no cracks, rusty. $25.00
400 Pontiac crank. Fairly fresh .010/.010 grind, should polish. $100.00
455 Buick crank core. Standard, no spun bearings. $50.00
3.8L or 4.1L Buick Grand National crank. Fresh .010/.010 cut. Very hard to find. $250.00
2.6L Mitsibushi steel crank. Fresh .010/.010, needs polished, has sat a long time $100.00
351 Ford Windsor crank. Fresh .030 main/.010 rod grind. $100.00
302 Ford crank. Fresh .010/.010 grind. $120.00
More stuff available, not sorted yet, call with needs.
JEFF is offline   Reply With Quote
Old 01-07-2015, 09:36 PM   #2
Vinnie78
Default Re: Blocks, cranks, heads, stocker part-Cheap-Mopar, Chevy,
Do you still have the 434 305 heads I'm also looking for a 2 bbl 305 intake and a complete motor I'm putting together a77 nova 305 . Let me know .vpg78@aol.com Vinnie green thanks
Vinnie78 is offline   Reply With Quote
Old 01-07-2015, 10:25 PM   #3
J.R. Haddad
Liked 1,469 Times in 308 Posts
Vinnie, I had 3-346260 intakes. Flowed them, kept the best one, then
bought a different combo. I still have the good one if your interested.
Thanks. J.R. Haddad.
J.R. Haddad is offline   Reply With Quote
Old 01-07-2015, 10:35 PM   #4
BARNHOUSECAMARO
Wink Re: Blocks, cranks, heads, stocker part-Cheap-Mopar, Chevy,
Complete 305 2 bl never apart out of impala have same combo 4 brl was bulding and collecting abandon project also 78 malibu short block and heads was 2 bl new let me know exact casting nos for your combos have 1 intake for sure might have 2 if any of these need to go to mike walters im 15 minutes from him 330-323-2998 i also go to western pa on fridays
BARNHOUSECAMARO is offline   Reply With Quote
Search this Thread:
Advanced Search
