Old 11-02-2014, 12:59 PM   #1
mykids
Liked 2 Times in 1 Post
Default CSI-BORLA-DYNAMAX-MOPAR-WELD & more
GARAGE SALE SICK OF WALKING OVER/AROUND THESE PART'S:
(2) USED WELD PRO-STAR 15x3.5 SPINDLE MOUNT WHEEL'S WITH ALL HARDWARE $225
(1) NEW IN THE BOX WELD PRO-STAR 15x3.5 SPINDLE MOUNT W/HARDWARE $200
(1) NEW WELD PRO-STAR 15x14 (6.5 B.S. 5x4.5 B.C. FORD/MOPAR) $250
(1) USED WELD PRO-STAR 15x14 (6.5 B.S. 5x4.5 B.C. FORD/MOPAR) $150
(2) NEW 1 7/8" HEADER COLLECTOR'S $100
(2) USED DYNAMAX COLLECTOR MUFFLERS 2" PRIMARY TUBE HPC COATED W/EVAC BUNG'S $225
(3) NEW BORLA SS COLLECTOR MUFFLER (40728) 2 1/4" PRIMARY TUBE $275 ea orW/Deal for 2
MY SPARE NEW NEVER USED (Chevy 168 tooth) CSI MINI STARTER $175
(2) USED CHASSIS ENGINERING REAR COIL/OVERS W/O SPRING'S $125
(1) POLISHED PG TRANS SHIELD OUT OF SFI DATE $50
(1) CSI FLEXPLATE SHIELD WITH ALL THE HARDWARE OUT OF DATE BUT IT CAN BE RE-CERTIFIED $45
(1) CSI P.G.SUPERSHIELD WITH ALL THE HARDWARE OUT OD SFI DATE $150
(1) NEW MOPAR PERFORMANCE PINION SNUBBER FOR AN 8 3/4" REAR $50
1 SET BBC 4 BOLT MAIN CAP'S AND BOLT'S
$100
SIMPSON CAM LOCK SEAT BELT'S OUT OF DATE
$30 PER SET
(1) COMPLETE 8 1/4 REAR DRUM to DRUM W/4:45 GEARS AND SPOOL UNBREAKABLE AXLES MEASURE'S 54 3/4" BACKING PLATE to BACKING PLATE --- CENTER PIN to CENTER PIN 43" $1250 OBRO
(1)SB CHRYSLER LAKEWOOD BLOWSHIELD BELL W/CLUTCH FORK - ZBAR & BLOCK SAVER PLATE $150
(2) TWO 15x8 WELD PRO-STAR WHEELS 5x4 3/4 BC WITH 4 1/2 BS $375 W/HOOSIER 30x9 RADIAL SLICKS
(1) USED MALLORY DUAL PT CHEVY DIST (TACH DRIVE) #2664501 $250
(1) USED CHEVY MALLORY UNILIT DIST $200
(1) NIB 7.5" GM PRECISION RING/PINION 4:10 GEAR SET $125
(1) USED ALL ALUMINUM 6.5" TCI HARMONIC BALANCER (RED)$100
(15) USED SB CHRYSLER ADJUSTABLE ROCKER'S AND SHAFTS $130 OBRO
(16) BBC ROLLER LIFTERS W/LINK BARS $250
CALL 508-TWO SIX NINE-9611 MORE TO COME
or E-MAIL ba1927@aol.com
DRAG RACE - STREET RACE - HI PERFORMANCE - MOPAR - FORD - CHEVROLET -HOT ROD - PRO/STREET - PRO STREET - SUPER GAS - NHRA - IHRA
mykids is offline   Reply With Quote
Search this Thread:
Advanced Search
