Old 10-05-2014, 10:25 PM   #1
DrJRacing
Default Re: Dan Fletcher Super Stock Videos - Opinions
My limited experience with vibrations involved a bad shock (front).
Was most noticeable after the run during shutdown. A fellow racer (Rick Ryan) noticed a bouncing motion of my front wheel ...told me to check my front shock ...I did ...he was right. Thanks Rick and Jerry Ryan!
PS Congrats to Dan Fletcher on his latest Wins! Keep us informed on the final solution
Doug Jonak
DrJRacing is offline   Reply With Quote
Old 10-06-2014, 10:02 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
By the video I don't believe it is driveshaft, I think you would see it on video when it happened,may be able to see on slow motion? I would think you would see moving during vibration,don't believe it is in the pinion angle changes or would have other spots in the run,because looks like angle changes are about the same,didn't notice a change when it vibrated.
In a way almost sounds like gear noise
Does this only happen at this one point during shutdown?
Mike Taylor 3601
Mike Taylor 3601 is online now   Reply With Quote
Old 10-06-2014, 10:10 AM   #3
Robert Simpson
Liked 20 Times in 12 Posts
If you have not checked it already I would check the ring and pinion and bearings. It sounds like it is when you are slowing down so it would not be on the load side of the gear but on the coast side. Plus all the loads are in opp directions on the gears and bearings. Hope you find it. Let us know..
Robert Simpson is offline   Reply With Quote
Old 10-06-2014, 10:39 AM   #4
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Talking Re: Dan Fletcher Super Stock Videos - Opinions
I think its the loose nut.............behind the wheel!
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 10-06-2014, 12:47 PM   #5
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
@ 26,27 sec it looks like the u joint is lose in the yoke.drive shift move but yoke doesn't.But I could be wrong
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 10-06-2014, 03:54 PM   #6
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Mike, you are the resaon I tune in to any thread involving Mr. Dan.
Dave Turner
SS/GT #1153
Old 10-06-2014, 05:10 PM   #7
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
Dan needs to fill everyone in all the stuff he did already.....But from what I recall of our conversation....everything that spins under the car from the front to the back has been replaced or swapped other than the actual ring and pinion - although it had all new bearings put in trying to find this issue.
So strike Driveshaft, transmission, tires and wheels, axel bearings, carrier bearings, and I think front hubs too off the list!
I was left scratching my head and had a long shot theory for him but once the Ring and Pinion get changed that will take one other thing off the list.
ATI Racing
ATI Performance Products is offline   Reply With Quote
Old 10-06-2014, 08:37 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
Looking at the second video ,it appears that there is very little pinion angle.
It may be decieving due to the camera angle, but it looks fairly shallow.
Considering it looks like a 3" mild steel shaft ,harmonics are a possibility.
I would at least try increasing the angle by 1-11/2 degrees to see if it has any effect.
I used to deal with this type of transient vibration on Jeeps and usually small amounts of angle change corrected the problem.
I also noticed what appeared to be a small ammount of play in the u joint at about 27 seconds, but that might just be the camera angle.
One other thought, if the trans yoke is one of the Spicer forged pieces , I'd check to see if the splines are twisted.... I've had at least three of them on cars with enough twist to cause them to bind on the output shaft.
