Old 09-12-2014, 05:38 PM   #1
Karl Owens
Default Re: Looking for Diesel Mechanic in Ohio
it could be related to the EGR delete and not causing a problem, the 02 sensor looks for a change when the EGR valve opens to check that system, the 02 sensor on a diesel is only on there to monitor the emission system not to alter air fuel like on a gasoline engine. Because of the EGR delete and reprogramming a dealer won't be able to help you, I would advise a really good performance diesel shop.
NHRA Stock/Super Stock 1078
Karl Owens is offline   Reply With Quote
Old 09-12-2014, 11:02 PM   #2
Paul Iaconis
Terry I don't know if this will help you call the skinners in Columbus they have a truck repair shop called Columbus joint and clutch great guys they could get you in the right direction
Paul Iaconis is offline   Reply With Quote
