Old 08-02-2014, 05:36 PM   #1
greatinspirational
Liked 30 Times in 14 Posts
Default 1993 Chevy Caprice Station Wagon NHRA weight break info
Does anyone know the weight break and horsepower ratings for the 93 Chevy Caprice station wagon ? When I download the 1993 file from NHRA I don't see the Caprice Station Wagon listed
greatinspirational is offline   Reply With Quote
Old 08-02-2014, 05:59 PM   #2
tj310
Default Re: 1993 Chevy Caprice Station Wagon NHRA weight break info
What motor are you planning on running ? 94 is listed, just switch taillights---Trevor
Old 08-02-2014, 09:36 PM   #3
Steve Williams
94-96 are LT1 engines. I don't believe 91-93 is a listed combination. 91-93's would be TBI engines. All 91-96 Caprice wagons are the the same in appearance with the frames being different for the LT1 wagons.
Steve Williams is offline   Reply With Quote
Old 08-02-2014, 11:28 PM   #4
greatinspirational
I wanted to run an LT1 in my 93. I would have to claim it as a 94 then I suppose
Old 08-02-2014, 11:43 PM   #5
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Get a 94-96 caprice Wagon.
Runs G, H/PS, M,N possibly O in Stock.
Corbitt Marshburn sold one recently.
Wagons are getting harder to find as a non woodie.
I have a 94 customized being set up for towing.
Check out impalassforum.com for more info.
D
Old 08-03-2014, 09:56 AM   #6
Steve Williams
I am not sure of how you do the passenger side motor mount with an LT1 in a 91-93. I know that the information can be found on longroof.com or impalassforum.com The 94-96 frames are different on the passenger side to accommodate the block mount being (what looks to me) upside down as compared to traditional small Chevrolet. I have a 94 and would have loved to bought Corbitt Marshburn's wagon, but just couldn't part with the money. I have wondered where it ended up, so I can look to see how the new owner is doing with it. Hope you build the wagon.
Old 08-03-2014, 06:52 PM   #7
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Aren't the blocks the same where the motor mounts bolt to , LT1 vs TBI , So if you had the V8 frame mounts and the matching engine mounts, what would be the problem ?
