#1 | |
Dion Hildebrandt 6009 STK H/SA |
#2 | |
Liked 13 Times in 11 Posts
Every aluminum rod failure I had pulled into in the middle. Big eng spun freely on the crank, with a good bearing inside. All big end failures I have seen were bearing failures. If it's black, it sure wasn't the rod.
When you set your bearing clearances, think about the expansion rates.
Ed Wright 4156 SS/JA |
#4 | |
That break was caused by the spun bearing.
Well , in the end , I blame myself for be stupid enough to A) continue to run it when I KNEW the rods had been in there for a while and B ) being too lazy to tear it down over the winter where I may have seen a problem.....but , like I said I'm a slow learner
Liked 972 Times in 309 Posts
Bearings don't usually fail by themselves. The connecting rod dimensions change or oil supply changes.
