Liked 799 Times in 236 Posts
Paul, did you change the filter with the fresh oil? -Al
"That'll never work....." Last edited by Alan Nyhus; 06-05-2014 at 06:07 AM. |
Liked 293 Times in 65 Posts
Liked 132 Times in 27 Posts
Did you use an oil restrictor kit?
Liked 288 Times in 90 Posts
After it warms up and the pressure drops, raise the rpms to 4000 and see if the gauge comes up to the 60-65 lb range and is steady. If it does I believe you are ok. The low pressure pump is just that ....low pressure. Just make sure its steady at the higher rpm range (4000).
If it fluctuates at 4000 rpms add a half qt of oil and check it again. Thanks for the info on the camper, that is what I need. RJ |
Still haven't figured this out. The oil pressure issue went away when I switched back to a plain ol' M55 pump, but the smoke won't stop.
So far, I've done these: Had .100 milled off the ends of the intake, because it was squeezing the rtv out and ending up metal to metal. Now it sits like it should. Switched out the Viton valve seals for Teflon. Still smokin'. Today I pulled the pistons, and there were no rings upside down or anything stupid. Stuck #6 back in upside down with just the oil rings on it and pulled it with a fish scale...had 10-11 lbs of drag. Now I'm out of options, so if anybody has more ideas, lay 'em on me. ![]() |
