First off, the car is available as-is rolling, it hit the wall on the driver side. It's a 68 firebird with a 10pt cage, stock suspension leaf spring car. Call to see car/make offer..
The whole front subframe could be purchased before any of these pieces are sold separately. $1700 gets the whole subframe, with motorplate/midplate for SBC. -AFCO 3840F/BNC double adjustable shocks, great shape $550 for complete bolt in coil over setup with 350# springs or $425 just for shocks. -Wilwood disc brakes, drilled rotors, 1 season old. Mint shape. $425 -Stock control arms modified for above shocks, with AFCO low friction bushings in lowers, uppers have stockers with serrations removed, free movement $300 -Manual steering complete with idler, centerlink, pitman arm, and new tie rods $250 Also have -9" ford rear for above car with SRD offset shackles (included), narrowed 2" per side, late big ford ends, Moser 35 spline axles, 5/8" studs, wilwood brakes, Moser thru-bolt aluminum center with 3.89 pro gears and big pinion. This rear end is literally brand new and has 4 runs on it. Has round tube bracing underneath, professionally built. $2200 -ARC touch panel and wiring board complete, $200 -Fender exit headers for SBC 1-7/8 to 3.5" with mufflers $600 Front and rear glass, as well as passenger side all good. Has 4" cowl hood, glass front bumper, all still good. Call with needs, listing for a friend. All prices are OBO...(516) 690-5325 Joe |
Liked 20 Times in 12 Posts
Joe, I'd be interested in the ARC panel. What model number is it?
