Liked 184 Times in 113 Posts
Pure Stock is what Stock was before the Unlimited Springs, unlimited cam duration and Mandatory high test fuel and roll bars. From1974 to around 1990.
The IHRA Rules book is very well written. Read carefully. Most of the rules are simple bolt-ons. Tires, shocks, traction bars, headers with mufflers. The three key areas are good set of gears, good converter w/ beefed tranny, blueprinted cam with stock springs. I like John at Bullet Cams. He will build you a cam that will pass and send the right springs. Suggest if you have the engine rebuilt go to a master engine builder who knows the stocker rules. Cost will be near identical to a normal rebuild from a normal engine builder. The advantage is knowing that the block and heads are spot on. The suggestion to call Mike Baker is also a good start to confirm what is a proper fit for your car. D Last edited by Dan Fahey; 05-18-2014 at 09:39 PM. |
