Old 05-08-2014, 09:07 PM   #1
james schaechter
Liked 1,428 Times in 296 Posts
Default Re: NHRA Levied Actions Against Don Davidson
I guess the question about this is the process as administered by NHRA. What then determined a need for a fine and if a fine is to be administered, what is the process to establish the amount?
If NHRA wants this to be a deterrent, why not spell it out? Unless the car had a dominator on it, it would seem that the punishment did not fit the crime here. The lift sure wasn't extreme.
Is this in the rulebook or amendments to the rulebook in a very specific way or is it written by a Chicago Politician?
James Schaechter 3163 STK
Old 05-08-2014, 09:42 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 779 Times in 193 Posts
Exactly. If this is going to be the way NHRA is going to be, they should let everybody know prior to the administration. Executive order, I guess. If you are needing money, nothing is off the table.
Old 05-08-2014, 09:44 PM   #3
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Based on what I have read.....the crime does not warrant the fine....note: I have been DQ'd for a half CC in the combustion chamber....later recinded. In this case....7 thou on the cam lift does not seem like much, but 1 thou is too much, but 1 thou would not get a fine...IMO....so the real question is....How big was the problem with the Carb? I'm just saying...
Old 05-08-2014, 10:11 PM   #4
NORVELL BOWERS
Send a message via Yahoo to NORVELL BOWERS
The Venturi area around the booster was .017 over size. I am not even sure how you could enlarge that area.
NORVELL BOWERS is offline   Reply With Quote
Old 05-09-2014, 11:17 AM   #5
John Nechiporchik
Liked 13 Times in 7 Posts
Out of curiosity, does NHRA have a requirement to calibrate their measurement devices on a periodic basis and provide documentation of such?
Having worked in Industry where precision measurement is required to determine part acceptability, procedures required calibration on a regular basis.
Additionally, utilization of such instruments require specific training and documentation of such training.
I'm new to stock racing and have not had the "teardown opportunity". But, if someone was to slap a $1k fine on me.....I'd be asking these questions as a part of an appeal.
John Nechiporchik is offline   Reply With Quote
Old 05-09-2014, 11:37 AM   #6
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: NHRA Levied Actions Against Don Davidson
Your statement makes complete sense. When the tool could make the difference between $1000 fine and disgrace or being a hero I'm afraid it only seems sensible to make sure the tools are correct and accurate. Jim
Old 05-09-2014, 12:01 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,919 Times in 576 Posts
I failed a teardown at the gators several years ago. My exhaust valve was .001 below the low limit. Wesley told me if I could find a caliper or mic that would read the correct size he would let me pass. I checked that valve with several calipers and they all measured the same. Needless to say I got bounced. Fixed the heads for the next race with new valves and picked up .08 so not all infractions make you go faster.
Mike Pearson 2485 SS
Old 05-09-2014, 12:04 PM   #8
Jim Wahl
Jim Wahl's Avatar
Talking Re: NHRA Levied Actions Against Don Davidson
Always knew you were a big time cheater! See ya Saturday! Jim
Old 05-10-2014, 11:01 AM   #9
David Daulton
Liked 19 Times in 4 Posts
Yes, it would be interesting to know how or even if NHRA documents the accuracy of their measurement instruments. In order to back up their findings at any given time they would need to provide documentation that their instruments have been certified by a lab that has ISO 17025 certification and that certification is current. The measuring equipment also should be required to be verified before use to a certified standard. This is all basic stuff contained in ISO TS 16949 which pertains to the automotive industry . And what about written procedures for their use of their equipment? All of this needs to be brought up if you contest a fine as I doubt they could back up any of their findings.
David Daulton is offline   Reply With Quote
Old 05-10-2014, 12:33 PM   #10
SSDiv6
Liked 1,580 Times in 582 Posts
You make a valid point.
In the cities of Medina and Bellevue, Washington, they passed a law called the "Bill Gates" law.
Bill Gates was known to always be speeding and getting tickets.
He will send his lawyer to court along with an electronics expert and the first thing they would question was the accuracy of the equipment, last time it was calibrated, the procedures for calibration and training for whomever perform the calibration.
When the police department could not provide the information, the judge had to throw away the ticket. After passing the law, other cities, county and State Patrol had to adopt the guidance. Therefore, when you get a speeding ticket, it will have the calibration information on the ticket.
