Old 10-05-2007, 08:19 PM   #1
ldyracr
Default Re: Valve Spring Selection
I was going to say the same thing about using the same spring again if I got three years out of them...lol.
I have used K-Motion and they just don't last long. I'm using Isky now and so far they have been good.
ldyracr is offline   Reply With Quote
Old 10-07-2007, 09:33 AM   #2
SlickVic
SlickVic's Avatar
Well everything on the motor was good to atleast 8000 rpms. I only turned it at max in really good air, 7600. Most of the time is wasn't over 7400. But, what i don't understand is the springs that came w/ the dart heads, the ones that lasted 3 years, only have a max lift of 650. Im running a 670/625 cam.
87 Cavalier, 92 Corvette, 72 Nova, 68 Firebird
SlickVic is offline   Reply With Quote
Old 10-07-2007, 10:46 PM   #3
Mike Hedger
Take out the lash from the total lift. .670 - .024 or so for lash. gets you under the .650 limit
Then if you figure in push rod and rocker arm deflection you loose a little more.
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
Old 10-08-2007, 04:36 PM   #4
SlickVic
SlickVic's Avatar
Lash on intake is only .012 which makes it .658...Whats deflection worth??
Old 10-08-2007, 04:51 PM   #5
Mike Hedger
I checked mine doing cam lift X 1.7 and it comes out to the .808 the cam is advertised as. Then I put it all together like you are going to run it but with 0 lash and checked it again and I come up with .799 at the valve. I tried three different rockers and they were all the same + or - .001 (Crane wide body rockers). But I have around 305 - 310# on the seat and around 800# open spring pressure so it is going to make things move around. I also run the spring within .050 of coil bind and they seem to last longer. I would guess that is why yours lasted so long they were close to coil bind so they did not surge when they were closing the valve.
Old 10-08-2007, 05:39 PM   #6
charliep
At 1.55 OD there are not many choices. I've had good luck with Comp Cams #999
charliep is offline   Reply With Quote
Old 11-10-2007, 07:19 PM   #7
SlickVic
SlickVic's Avatar
Doing some measurements. Was looking at 1.6 rockers to give some added lift. After doing all the calculations, i ended up with .027 clearence before coil bind on the valve spring. Too small? Whats the recomended?
