Old 04-11-2014, 02:29 PM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Default Any one switch from Hoosier standard radial to lightweight?
Has anyone back to backed standard weight drag radials with the lightweight versions?
Not sure if the standard weight tire is the same tire with more rubber or not. Although the standard is listed as a C07 compound and lightweight as a C06.
Can you run more tire pressure in one over the other?
Thanks
Eric
Eric Merryfield 1883 STK
