Old 03-22-2014, 05:04 PM   #1
russellauto1
Liked 35 Times in 6 Posts
Default Re: New D/PS Firebird
Wow did not want to hear that. I rebuilt my rear end with aftermarket axles, 4.56 gear, solid pinion spacer,( which I hope makes a huge difference) new bearings, bars to support front of pinion to axle tubes, rear cap girdle cover, tig welded axle tubes, and 85w140 gear oil to hopefully take some of the shock . I then cut the housing ends off and straightened the housing . I put 8.5 x 26 m&t on the back. But I am going to leave 15 or so psi in them. That is an awesome new best time. I hope I can get my car to et that low. I think the tracks will start to open next week so I will let you know how it goes.
russellauto1 is offline   Reply With Quote
Old 03-23-2014, 11:11 PM   #2
KennyAnderson
Liked 357 Times in 119 Posts
Sounds like your rear oughta be good to go. All my guru buds told me not spend a penny on the 7.5" ten bolt especially since this car might become a crate motor or legal stocker down the road. I've been planning the 12 bolt swap since day one. Just hoped to do it down the road a bit. Got to looking at what it will entail to open up the wheelwells for a 30" tire. Looks like a BUNCH of work, especially behind the pass side tire. 28's might have to do for now.
KennyAnderson is offline   Reply With Quote
