Liked 364 Times in 138 Posts
Dan, the length of the trailer will be an important aspect of your comparison. You don't mention the dimensions of the 1300 lb example in your post. My rough guestimate would be 2 1/2 to 3 times heavier.
You could safely tow a 20-22ft enclosed unit with a 1/2 ton truck or SUV. Anything longer than that, no matter the construction, and I would advise you to upgrade to a 3/4 ton. I can't give you any input on the comparative weights of trailers from competing manufacturers...sorry.
Dave Turner SS/GT #1153 |
#2 | |
Liked 184 Times in 113 Posts
That is good information. The Aluminum Trailers were Featherlight and ACA 17.5 and 18 ft long. My problem is storage of the Trailer. Live in Germantown Md. D |
Liked 33 Times in 16 Posts
Dan - I tow an open all steel trailer with a 2004 Silverado SB 1500. It has the 5.3 engine and 3.73 gears w/automatic. I have no idea of the trailer weight, but it has to be way heavier than a aluminum version. Trailer has brakes and the truck does very well, but I don't tow over 65mph. A recent addition of Helwig air bags made it much better to tow with...no more scissor action after road dips. I like to keep an eye on intervals due to what I feel is marginal braking with this set-up.
Rich Taylor I/SA - 321 |
#4 | |
Liked 85 Times in 22 Posts
It sat level before the addition of the airbags...still handles really well. I will drop the ball a couple of inches next outing and see what it looks like. The bedliner coating is holding up well so far.
Rich Taylor I/SA - 321 Last edited by HandOverFist; 03-18-2014 at 03:53 PM. |
#6 | |
What bed liner did you use? D |
Rustoleum from AutoZone...$59 a gallon and I sprayed 2-1/2 gallons total on the entire trailer.
#8 | |
Have a 1994 Caprice Wagon that I have been customizing and fixing up for a few years. It has airbags, Belstein Shocks, rebuilt the ABS and Brake systems at a good cost. New Trans lots of stuff. Have a new engine being built. The current engine has 212k miles but does not burn any oil. Use to leak but got all that fixed. D |
Liked 56 Times in 29 Posts
My 21' Target open weighs 1370 lb. I can send you a pdf of the Wells Cargo brochure showing their lightest enclosed with 18' box is 2900 lb.
#10 | |
Liked 5 Times in 5 Posts
Danny Durham |
