Old 02-26-2014, 07:14 PM   #1
ken robinson
Liked 224 Times in 87 Posts
Default Re: Header Retention Rule Revision
signman my set up was legal the whole time .....bob too .........wow
Old 02-27-2014, 09:07 AM   #2
Dan Fletcher
Sponsor
Dan Fletcher's Avatar
Liked 1,045 Times in 70 Posts
The clarification didn't clarify much to me. I still have no idea if a normal race car set up consisting of 4 primary tubes with a 4 into 1 collector that has 2 tabs with 1/4" bolts like 90% of us have is eligible for an Advance Auto muffler clamp and hanger.
What I do know is that the Collector Tethers that I ordered came on time and fit perfectly. Fitting perfectly might not sound like much, but I had very specific dimensions with no real margin for error. Moreover, I took them on an airplane with me to Cali, so if they were wrong I was pretty much screwed.
I think this has been the most overblown deal I've ever seen. It's not like they're saying you have to buy new ones every 2 years, it's a one time deal. Mufflers were worth fighting about, this is not, IMO.
Dan Fletcher 1781 STK, SS, COMP, SG, SC
DAN FLETCHER TRAILER SALES
Dan Fletcher is offline   Reply With Quote
Old 02-27-2014, 09:52 AM   #3
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Very well said.....
Mack Reeves
2377 STOCK & SUPER STOCK
Old 02-27-2014, 10:06 AM   #4
Jeff Teuton
Liked 325 Times in 50 Posts
It is a little muddy. My understanding all along was the tether itself should be minimum 1/8 SS cable, and a loop of some kind on each end secured on a primary tube and the collector with a T-Clamp (Aircraft Clamp and several other names). Or you could have used a tether with a loop on each end, the collector end secured by the T-Clamp and you could bolt the other end to the frame with a bolt thru the frame. I have sent this to NHRA thru SRAC for clarification. Sometime what they mean and what gets printed is different. There seems to be confusion on the multi piece exhaust that run all over the car like plumbing pipe which I think some Fords got.
Jeff Teuton 4022 STK
Old 02-27-2014, 10:36 AM   #5
Signman
Liked 269 Times in 99 Posts
NHRA is requiring 2 methods of retention if you headers have removable collectors. Conventional method plus one of 3 options.
Old 02-27-2014, 11:47 AM   #6
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Mine is good !!!!
Bob Bender 144 O/SA
Old 02-27-2014, 03:51 PM   #7
buzzinhalfdozen
Liked 11 Times in 8 Posts
Dan, I don't think it's the cost of the parts (though it may be in some cases) needed that has most scratching their heads. I believe it's the apparent vagueness of the wording and the revising that has most wondering...my self included. Heck less than 100 dollars and you're sweet, but again why put it on if the NHRA is just gonna rescind it or change it again. Merely my opinion. Joe
Joe Buchanan SS/BX 3117
Old 02-27-2014, 04:05 PM   #8
Jeff Teuton
Per NHRA. Three methods of retention. Collector welded to primary tubes; approved tether, or hanger attached to body and collector so it can't fly off. I think all the details have already been talked about. The third option (hanger) is the newest. I think it is worded badly, but they want something bolted or attached to the body so it can't be removed very easy. I think we all knew about the welding and the tethers. I think Dan is right; it's just not that big a deal and it's once only. I am the messenger only.
Old 03-01-2014, 09:18 AM   #9
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Old 03-01-2014, 09:27 AM   #10
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Got casters on the bottom?
Rich Taylor
I/SA - 321
