Old 02-26-2014, 02:18 PM   #1
prixmoracing
Default Re: Header Retention Rule Revision
Originally Posted by FED 387 View Post
Signman---Please reread the rules again # 2 is the only option---- #1 no longer a valid way of securing them per NHRA rules---If it has a removable collector it will have it secured by the following means (your choicepick one of the 3) weld/tether/body mount that's it!! FED387
Reread what he said and he is correct, 1: you need to use the current tabs/springs/bolts to secure and then in conjunction with that 2: one of the 3 now allowed options (tether or weld or Bolt/Mechanical fastener to frame)
Unfortunately those with the least amount of common sense are completely unaware of their situation....
prixmoracing is offline   Reply With Quote
