It would be slick if you could run a factory pump at a constant speed with n electric motor to measure how long it takes to pump a quart, or whatever. Do they rate them in gallon an hour, like a fuel pump? (I'm thinking not) Then do the same with your dry sump pump. Might be a trick to get an electric motor to run at a constant RPM with both pumps. May be easier to do it off a gasoline engine. It would be interesting to know if shortening the housing and impeller 10% would get a 10% drop in volume pumped.
During the 1980s I ran an "outlaw" sprint car on dirt, (didn't drive it, you can hire crazy people for that) with a Peterson dry sump set up. I felt like it was way more pump than I needed. Never did play with that, making enough power was never an issue. Always wondered about that pump. I'm sure it was over-kill in size to cover their tails.
Ed Wright 4156 SS/JA |
#2 | |
Oil pump flow is measured in GPM. The flow will vary based on the relief settings. Your best best is to call the tech guys at Peterson or Dailey. This link is a good article regarding engine bearing lubrication: http://www.epi-eng.com/piston_engine...e_bearings.htm |
Liked 333 Times in 180 Posts
suggestion ----Joe you know Brian Browell he runs a Chevy V6 call him run it by him a Ford or Chevy gotta be pretty similar I would think see what he says--or talk to Bob Huettman he could check wth some of the NASCAR guys see what they ran---FED 387
Liked 2 Times in 1 Post
Years ago I modified some Melling m55 oil pumps for small block chevy stock eliminator engines. I cut the gears down and cnc machined a plate to go in the bottom to take up the space I also did some other modifications. I did some 1/4 " and some 3/8" pumps. The 3/8" pumps were worth 9 horsepower more than a m55 in back to back dyno tests.I was planning to tap into the bypass circuit and plumb in a flow meter to monitor bypass flow. About that time Schumann started making pumps and I was raising my son so I didn't have time to pursue it. If you can monitor bypass flow you could find out how much oil pump you need. Derek
Derek Hake 4459 H/SA 69' Roadrunner |
#5 | |
Liked 11 Times in 8 Posts
Joe Buchanan SS/BX 3117 |
#6 | |
Liked 269 Times in 99 Posts
Have run the Stewart pump in my stocker. If you like make an offer and you can have it.
The Schuman pump is a good deal. You may need to do some fabrication to make their latest model work, you will not be disappointed.
