If the rules allowed a different ratio trans it would be much more managble. That much low gear in a light car will keep you busy adjusting it. Mine was like a tractor. Spinning the tires or standing straight up. :-) The big RPM drops at shifts don't help anything.
Think tech would notice a metric 200? LOL
Ed Wright 4156 SS/JA |
#2 | |
Liked 360 Times in 121 Posts
Does the Bullet "blueprint" cam keep factory duration? Is that even published? If it has more duration your RPM range will be higher. On-track testing I have done with both my bone stock virgin LT1 Camaro & TA (not even headers that would effect it) showed quickest ETs (with proper tuning) shifting it at 6000 RPM. I'm not sure what you are seeing on an chassis dyno sheet that tells you the needed stall speed. You do realize, that with an automatic car running a loose converter, the numbers are skewed (out of sync with the torque numbers), right?
#4 | |
Liked 184 Times in 113 Posts
The engine was dynoed by Jeff Warren after he built it. Btw where do you have a dyno? D |
#5 | |
The chassis dyno in my shop for fifteen years. I now dyno my SS engine on engine dynos at either Patterson Racing Engines or Morton's Machine.
#6 | |
Mine was easy because the NHRA/IHRA uses the F-Body Cam specs for B and F Body LT1s. Where is Patterson and Morton? D |
Patterson Racing Engines is in Augusta Kansas (Edge of Witchita, about three hours drive)
http://www.pattersonracing.com/ Stanley Morton has a smaller shop. He is in Broken Arrow, OK, about half an hour drive. Patterson's dyno set up has eight wide bands, Stanley's does not. Depends on what I need to do. Patterson builds Stock, SS and Comp engines mostly. Stanly builds Pro Mod and Top Sportsman stuff, also the best crank shaft guy I know. Known both Stanley Morton and Allan Patterson for about forty years. They both also do machine work for me.
Yeah, a Pro Trans. LOL
