#1 | |
Liked 184 Times in 113 Posts
I am trying to get the one in F or G...Just happen to have a lot of competition. So what if it was 12 under...you have proper bragging rights!! Think I will come bearing parts and come early. Lot of guys griping my car is not legal. If you are there it will be a snap to put it back together. Need to bug Mike Baker about getting Points for Setting National Records. Guarantee you will see a few NHRA guys trying to dominate that opportunity. D |
#2 | |
Liked 359 Times in 120 Posts
I like the way you think! Main thing I got to do it put the headers on. I havent removed the stock manifolds yet and I PRAY I dont snap off any of the old bolts. Yep, bug Mike Baker. I think some points would be good. From what the tech guy was planting in my head, I would get 20 for setting it in D, can only get those once. THEN I could get another 20 by dropping down to C and setting that one. I thought it was too good to be true as 40 bonus points at the end of the season could turn a zero into a hero right quick!
Liked 66 Times in 37 Posts
Nice meeting ya and hope to see ya in Lakeland for the Southern Assoc. race. Daran
72 cutlass |
Nice meeting you too Daran. Don't know if I mentioned it but I work for the Fire Dept down here for my real job. I just looked and I'm on duty on the 22nd. Might be able to get off but I'm already trying to get a couple shifts off the next weekend for Jackson, SC. We'll see.
Liked 313 Times in 106 Posts
I have the D record set 8.078 83.44 IHRA never has put in book or sent me certificate.
Set @ london last year I need to call them. Mike Taylor 3601 |
Liked 372 Times in 130 Posts
I noticed that Mike.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Well, Looks like I need to get BUSY!! LOL! I was going to go down to C for Jackson, BUT Since the GAUNTLET is Thrown........
![]() ![]() ![]() Seriously Mike how much did they want to see when you set it. I'm not real excited about teardown and its OBVIOUS this motor has never been apart. PM me if you want. |
Kenny,
They will check bore,stroke,deck clearance,piston dish in my case,cc head, gasket thickness,cam lift, look at lifter,runners..... duration,spring pressure? Jim Woods knows my engine well,probaly has my specs memorized LOL The best way is take your car apart @ home,have head,intake etc. clean ready to go back together,I always set head,intake,bolts,pushrods rockers etc., all back in place @ home basically put all back together and just start bolts,that way you don't get to track putting back together and find out you left something @ home. Show up on first day of pro am Friday of Sat. and Sun races,I always call the tech man and see when is good time to be there. Since yours has'nt been apart this would really be good ideal, in case you have broken bolts or anything else that might need fixed. Measure head diameter of valves,they get bigger after miles,will flatten out 45 and make burr,best description around valve and cause head to measure big. LT won't be too bad to put back,lot easier than LS,I know guys take heads off LS in the car,but I believe I would just as soon drop engine out bottom, I had to put water plug in pass head of my sons I left out ,I thought I was going to have to drop engine back out to get it in there, finally got it though. Mike Taylor 3601 |
