Liked 360 Times in 121 Posts
Keep me posted on your plans Dan. We'll be in Bradenton fo sho!
Liked 184 Times in 113 Posts
Liked 316 Times in 107 Posts
Kenny,
You did'nt pull the old trick a truck puller customer of mine used to do did you? They had stock class they would put new engine in truck that was about 12 colors,I think each body panel was from different wrecked truck,then they would pour used diesel oil over engine,then bucket of dirt,looked like 150K miles,could'nt even tell had brodix heads,cast iron bowtie intake was all hidden well. Just aggravating you,hopefully you have sense of humor. Congratulations on your record Mike Taylor 3601 |
#5 | |
That is what the Circle R was all about on your car !! You set a National Record........just clicked ! A Big Congratulations !! That is an OBD (Official Big Deal) ![]() |
#6 | |
Thanks Dan but I'm almost embarrassed about it. There is no record in D and I only went 12 under. I did it cause the Tech guy told me there was points to be had. (misinformed-no points) I got the motor sealed. To make it official I need to go thru teardown which is a PITA in this car. I plan on dropping to C/PS very soon. Probably before Jackson at the end of the month. |
#7 | |
I am trying to get the one in F or G...Just happen to have a lot of competition. So what if it was 12 under...you have proper bragging rights!! Think I will come bearing parts and come early. Lot of guys griping my car is not legal. If you are there it will be a snap to put it back together. Need to bug Mike Baker about getting Points for Setting National Records. Guarantee you will see a few NHRA guys trying to dominate that opportunity. D |
#8 | |
I like the way you think! Main thing I got to do it put the headers on. I havent removed the stock manifolds yet and I PRAY I dont snap off any of the old bolts. Yep, bug Mike Baker. I think some points would be good. From what the tech guy was planting in my head, I would get 20 for setting it in D, can only get those once. THEN I could get another 20 by dropping down to C and setting that one. I thought it was too good to be true as 40 bonus points at the end of the season could turn a zero into a hero right quick!
