Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 01-13-2014, 11:13 AM   #1
Bob Shupe
Bob Shupe's Avatar
Default Re: 2014 COPO Engines
Originally Posted by GUMP View Post
It seems to me that the problem with the 427 is the weight break being at 450 for the shootouts.
For the regular classes, I think that Chevrolet has done a very good job of looking after the older N/A combinations.
Mr Adams is this going to be a plan for the BODY IN WHITE???
Bob Shupe is offline   Reply With Quote
Old 01-13-2014, 02:05 PM   #2
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
the 450 is a .100 stroked 427, same bore od 4.125, with mechanical roller lifters and they must have changed the head because there is a different part number. Fun to own one. Dyno
Old 01-13-2014, 03:04 PM   #3
Mike Keener
Liked 24 Times in 13 Posts
Different piston config, more cam, more intake runner volume, bigger valves, more rocker ratio, etc. About the only thing you can use from a 427 are the rods, the manifold and throttle body, and the block.
MK
Mike Keener
A/S B/S
C/SM
Mike Keener is offline   Reply With Quote
Old 01-13-2014, 03:56 PM   #4
GUMP
Liked 2,359 Times in 557 Posts
Originally Posted by Mike Keener View Post
About the only thing you can use from a 427 are the rods, and throttle body.
I think it would end up more like this.
Old 01-13-2014, 05:04 PM   #5
Mike Keener
Nope...same exact block with a 4.200 arm, and the manifold and throttle body are exactly the same as the 12 and 13 427's.
MK
Mike Keener
A/S B/S
C/SM
Old 01-13-2014, 07:44 PM   #6
GUMP
Understood, but I am sure that we will see this combination "evolve" a little before it sees an NHRA event.
Old 01-14-2014, 08:22 PM   #7
Jeff Teuton
Liked 325 Times in 50 Posts
Started the process today to get that .200
Jeff Teuton 4022 STK
