Old 01-08-2014, 12:14 AM   #51
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
Default Re: Removing Decals
Aircraft stripper works the best!
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 01-08-2014, 12:57 AM   #52
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Originally Posted by Sean Cour View Post
Angelo, go to the automotive paint supply store and purchase the die grinder with eraser wheel attachment. Astro tools sells the product. You will need a couple eraser wheels to remove a lot of decals. The wheel is a four inch eraser, and it works great.
thanks - I'll check into it
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 01-08-2014, 04:38 PM   #53
John Kelley
"AIRCRAFT STRIPPER" ??
We're trying off decals NOT PAINT !
John Kelley is offline   Reply With Quote
Old 01-08-2014, 07:58 PM   #54
Ed Wright
Ed Wright's Avatar
If Sean tells you it's safe, it's safe.
Ed Wright 4156 SS/JA
Old 01-08-2014, 09:11 PM   #55
Angelo DiTocco
LOL - if he says its safe to surf is it safe to surf??
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Old 01-08-2014, 09:13 PM   #56
Ed Wright
Ed Wright's Avatar
You have to watch those guys out west. LOL
Old 01-09-2014, 09:59 AM   #57
jstrick2010
jstrick2010's Avatar
Hey everyone. I can't believe no one has mentioned this yet. We have a sign shop and have a commercial glue remover that would take you maybe 5-10 minutes (per side) to remove all the glue. It will NOT hurt the paint or clearcoat! Also when putting your decals back on, we make a one piece decal to fit your car. Give me a shout if you need any glue remover, we buy it 5 gallons at a time. The only problem is you won't get to sit around for 5 hours and drink beer while you work because you'll be done in 20 minutes! 256-810-6162
Jeff Strickland
jstrick2010 is offline   Reply With Quote
Old 01-09-2014, 01:17 PM   #58
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Are you saying it softens the glue under the decal for removal or just removes the residue after decal removal?
Rich Taylor
I/SA - 321
Old 01-09-2014, 02:29 PM   #59
jstrick2010
My apology....It will remove the glue. We use a razor to get the corner started up on the decals the peel them by hand. A little heat is good, a lot of heat can make it worse (they'll stretch & leave ALL the glue) and some of them don't matter what you do they are a pain. All depends on the material the decals are made of. We then use the remover to get the glue. It won't soften the decal for removal. Only way to do that is elbow grease or a rubber wheel on an air tool (which makes a mess!) but it works. If you ever try the one piece decal wrap, you will never go back. They can be removed in 5 minutes with no leftover glue.
Jeff Strickland
Old 01-09-2014, 02:43 PM   #60
HandOverFist
Where can you purchase this wrap Jeff? I'll assume it is clear...you cut it to fit a specific area? I'm thinking the lower door panels and fender quarters.
Rich Taylor
I/SA - 321
