Old 01-03-2014, 11:09 PM   #41
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Removing Decals
Originally Posted by Steves68Nova View Post
Lots of great ideas. My problem is a little different, I have a decal of a drivers name on my plastic windows and now have changed drivers. Any ideas on how to remove the decals without screwing up the windows? Also if I ever join the HRA's again I am sure I will not get the same numbers. They are on the windows too.
be very carefull on lexan if they are coated style abrasion resistant lexan windows. the coating can come off like saran wrap.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-03-2014, 11:21 PM   #42
voltdr
Liked 100 Times in 51 Posts
3M Adhesive Remover works great, and the plastic razor blades are a big help. Autozone, Orielly's has it on the shelf......
voltdr is offline   Reply With Quote
Old 01-04-2014, 12:34 PM   #43
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: Removing Decals
Should you drink the beer for several days before you start?. Just wondering!
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 01-04-2014, 01:15 PM   #44
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
Angelo, go to the automotive paint supply store and purchase the die grinder with eraser wheel attachment. Astro tools sells the product. You will need a couple eraser wheels to remove a lot of decals. The wheel is a four inch eraser, and it works great.
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 01-04-2014, 02:47 PM   #45
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
This is also very good advice.I used one that I got from Advance Auto to remove some lettering on an enclosed trailer.Worked better than expected.Helped justify the over $40 price tag.
3M Adhesive Eraser Wheel
Part No. 3612
Old 01-04-2014, 10:44 PM   #46
gbur
Originally Posted by John Kelley View Post
Does it affect the paint underneath the decal ?
I found this on KleanStrips web site....http://www.wmbarr.com/product.aspx?catid=33&prodid=121
Now if I can find a place to buy it .....!! Might have to take a trip to Dallas...except in the rush hours, if there is such a thing !!
home improvement stores sell it, hasn't hurt any paint here yet
gbur is offline   Reply With Quote
Old 01-04-2014, 10:53 PM   #47
Ed Wright
Ed Wright's Avatar
I've never had a problem getting them off with just a heat gun. I get the glue off with Safety Kleen parts washing solvent, it won't bother the paint. Never had to use anything else.
Ed Wright 4156 SS/JA
Old 01-04-2014, 10:58 PM   #48
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
heat gun for the bigger ones, get heat just right glue will come with it. any glue residue use wd 40. wont hurt paint at all. for the small or multiple letters or very thin vinyl use the eraser wheel. this combo can get an entire cars decals off in under an hour.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 01-07-2014, 12:32 AM   #49
hemidup
Originally Posted by Lyn Smith View Post
Wax and Grease remover works best for removing the glue.
^^^This..... much better/faster than WD40. Also works great on removing the rubber from your rear rockers.
Jerry Williams
NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's.
hemidup is offline   Reply With Quote
Old 01-07-2014, 09:37 AM   #50
Ed Wright
Ed Wright's Avatar
Parts washer solvent works well for both also. Just dip a rag in your parts washer if you don't feel like driving to the auto parts store.
