Liked 799 Times in 236 Posts
Front suspension apart for a freshen-up......bushings, control arm shafts, ball joints, etc. Will also treat it to some lightweight disc brakes. Once that's back together the motor will go back in:
![]() Relocated and raised the shifter with some 6061 I had laying around: ![]()
"That'll never work....." |
Liked 33 Times in 16 Posts
That's clean Al...I really need to do something with our shifter as well.
Rich Taylor I/SA - 321 |
Rich, the round stock is 3/4". With a .750 counterbore, I went .125 deep in the plates as a register for the round stock, faced off the ends of the round in my lathe, drilled and tapped the ends of the round 1/4X20 and used a standard 82 degree countersink for the flat head Allen screws. You could also just have it TIG'd and simplify the deal.
Took longer to clean up the chips than make the part. Not really....... -Al
"That'll never work....." Last edited by Alan Nyhus; 01-04-2014 at 11:41 PM. |
What brake components are you going with? We ended up having to space the m/c off the firewall using the Bickel piston rod kit...had a high pedal and it was not fully retracting. http://www.jerrybickel.com/brake-kit...-jbrc1064.html
Rich Taylor I/SA - 321 Last edited by HandOverFist; 01-05-2014 at 12:18 AM. |
The last couple of weeks has been some non glamorous, greasy, knuckle bustin' stuff. Urethane bushings for the upper control arms and offset shafts:
![]() On the lowers, urethane bushings, new control arm bolts, new inner and outer tie rod ends and adjuster sleeves, new upper and lower ball joints and new springs. After getting everything stuffed back together, Steve Koppien and I counted our fingers. We came up with ten each and considered the job a success....... ![]() New Mickeys on 9" Bogarts, ARP studs and J&J Racing Products stud sleeve and nut setup: ![]()
FedEx dropped off a box full of Aerospace brake stuff. The only hiccup in the install were the rotor mount holes. My bet is they thread these holes early on in the process and the threads move around a bit during heat treat. A quick touch up of those and life was good again:
![]() The stuff looks so nice it's a shame to cover it up: ![]() Next............. ![]()
Liked 18 Times in 12 Posts
How much quicker are you anticipating all of these changes/improvements are going to make?
"Real Race Cars Have Tailgates" |
