Liked 4 Times in 4 Posts
I am going stir crazy! I can't work on the car outside, and I see a couple more of these builds popping up, albeit all 75's. None in Division 6 that I know of yet though (I hope at least until I know what mine can do lol). I just want to get back to it! I'm getting nervous and ancy, and though I know mine is on a McBudget, my competitive streak is burning! I did order some front wheels, since the 54 Ford ones were too crusty for me, but not much else. It's not looking like it will be a mild winter either.
Joe Toller Lewistown, MT |
Well, not much new here, just clearing up some unused pieces and whatnot to make room, I am planning on getting a converter from Mark Yacavone, and the correct 77-vintage cam (I have a 75-correct grind now).
I did pick up a new budget tip to share: alot of guys look for donut spare wheels, and the fox-body Ford guys have good 4-lug versions in aluminum. But, the 5-lug Ford/Mopar/AMC guys have an option too: 94-02 Mustangs (especially GTs) came regulalrly equipped with 15x4 aluminum compact spares, with the 5 on 4.5 pattern. They are very common and cheap (except on ebay), I bought a pair for $40. Check your local yards!
Joe Toller Lewistown, MT Last edited by Joe Toller; 12-31-2013 at 08:12 PM. |
Liked 393 Times in 153 Posts
This was brought up a couple years ago at our local track as it is a cheap alternative to aftermarket rims, here is the answer straight from Mike Baker;
From: "Baker, Michael" <mbaker@ihra.com> To: Subject: RE: T-Bird temp spare wheel Date: Mon, 7 Feb 2005 08:03:41 -0600 ------------------------------------------------------------------------------ I would not think they would be legal based upon their intended use and speed. Only OEM or SEMA approved aftermarket wheels should be used in a drag racing application. ---------------Original Message------------------------- Subject: T-Bird temp spare wheel Question: Are the narrow aluminum "temporary spare" rims from a Ford T-bird legal if they have frontrunners and tubes mounted on them? I need the "official IHRA position" on this question as I have a lot of people waiting for the answer. -------------------------------------------------------------------------------------------------------------------------------------- Now him saying "I would not think" is not a direct "no", but I think the intent is to discourage people from using them. What would happen at your local track? Depends on Tech. |
Liked 275 Times in 76 Posts
The aluminum spares have been used on several stockers over the years, along with street strip cars too. I believe they are a full size spare, so with a good tire there should be no issues at the track. The original tire would be the issue at the track, as those are not rated to exceed a certain MPH.
Sean
Exactly. The wheels are adequately load rated 15x4 wheels, it's the tires that are not suitable for high speed driving. A pair of 165/80R15 radials up front, on a slower stocker especially, would be a nice budget setup for under $200.
Joe Toller Lewistown, MT Last edited by Joe Toller; 01-01-2014 at 11:51 AM. |
Liked 27 Times in 14 Posts
Many years ago, I was told by Travis Miller that the Alum spare wheel was NOT allowed to be run. I had them on my car along with a pair of centerline polished autodrag wheels.
Bracket racing nobody cared, or noticed. 1st points meet I got the "when you get home, you need to change........" I suspect Travis can update that statement from 1997...... |
Quick question...I assume most of you in this debate were going faster than 14 seconds? I could see a faster car maybe not using them. Bear in mind as you weigh in here this is a slow car, and the info I am sharing is for a slow, budget-oriented build.
I sent an email to my tech director, I will go with his recommendations.
