Old 12-08-2013, 09:57 PM   #8
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Default Re: Nova stocker project.
Alan,
I like the fuel pump mounting plate but I was always told you need to mount those Holley style pumps lower than the tank . I may be wrong or the picture may be misleading you may have enough fall there.
Holley's instruction sheet says
Mounting and INSTALLATION:
The best location for mounting any electric fuel pump is the rear of the vehicle. The inlet and outlet of the pump must be mounted below the lowest point of the tank. This is necessary to allow for an adequate fuel supply. The pump is designed to push fuel and not designed to suck fuel out of the tank. It needs to be gravity-fed or if it’s pulling from the top of the tank, it needs to develop a siphon feed to the pump. The pump should be mounted on the chassis, in a vertical position with the pump motor on top
Also being in FRONT of the pick up the fuel may need to overcome the launch G's, remember it's gravity fed basically
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
