Old 12-08-2013, 11:18 AM   #1
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: Factory Showdown Cars and Indy 2014
I think it's pretty simple:
If you are running with/as part of Stock Eliminator, AHFS applies. -1.219 under = Horsepower penalty. Period.
If you are in a shootout of your own, with no AHFS or other stuff, you are seperate from Stock and not part of the 128 car Indy field.
Old 12-08-2013, 11:31 AM   #2
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: Factory Showdown Cars and Indy 2014
I like the factory cars and would probably have one if I could afford one. It would be a stick! I do think they should be in their own class. The new cars beat up on almost every A/SA and B/SA car that was running. Many are gone now. I suspect that will change when the new cars finally get where they belong.
By the way, it is 40 cold degrees here in Covington, La. Freezing my behind off! But we're in the garage working on the car trying to find more H.P. That much never changes. And it never will!
Good luck to all.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 12-08-2013, 12:11 PM   #3
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
All great ideas!
IMO, AFHS needs to be in forced if your running stock.
It's only 7 degrees in Denver. COLD!
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 12-08-2013, 03:06 PM   #4
goinbroke2
Liked 393 Times in 153 Posts
X1000!!! Can't get any more simple than that!
Your all in or your all out, period!
Old 12-08-2013, 04:16 PM   #5
Dyno
Dyno's Avatar
Liked 692 Times in 205 Posts
I brought the hemi home on Monday when it was a warm 28*, -14* on Friday night, snow and a warmer 8* this Sunday. Dyno (Mpls., Mn)
Old 12-10-2013, 07:03 PM   #6
Clay Arnett
Clay Arnett's Avatar
I understand why NHRA does not have AHFS apply to the class because they want flat out heads up racing. Which is reasonable who doesn't want to see that?
So how about they just say no AHFS for any cars at Indy? That way we can see everyone let them loose.
I do think they need their own class and should be showcased more.
Clay Arnett is offline   Reply With Quote
