Liked 165 Times in 51 Posts
The new kit has one without the ball. Do you think it will be ok?
Glen DeMenge 1969 Camaro Stock Eliminator |
I would not use a needle that does not have spring stabilization in a boat, if the original had one in it. The rough ride you get in a boat on the water bounces the float around a lot, and you'll have problems with keeping a stable fuel level in the float bowl. A Q-Jet is fairly sensitive to fuel level for metering purposes.
Alan Roehrich 212A G/S |
#3 | |
we used it over it vacuum tested fine and was working when removed.
Thanks for the help. Quote:
