Old 11-19-2013, 11:34 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 396 & 427 Shortblocks and Parts
1969 427 L88 CE warranty standard bore shortblock casting #3963512 dated A-28-9 stamped CE962182. Block has the original pistons, 7/16 dimple rods, 7115 steel crankshaft/ camshaft with lifters and 8 inch harmonic balancer. Purchased over the counter new in 1969 from a dealership and was only balanced when freshened up. Very clean with all cylinders greased down $6500.
1969 427 4 bolt 30 over CE warranty rebuilt shortblock casting #3963512 dated G-21-9 stamped CE966446. Block has the high dome pistons, 3/8 dimple rods, 7115 steel crankshaft, cam and lifters and 8 inch balancer. Aluminum waterpump on it as well stamped #5421 $4500.
1969 427 4 bolt rebuilt shortblock 30 over with #L2268 replacment dome pistons casting #3963512 dated G-2-9. 7115 steel crankshaft, 7/16 dimple rods, cam and lifters, waterpump 3856284 and 8 inch harmonic balancer. Block is decked and has one sleeve installed $4500.
1969 427 4 bolt standard bore rebuilt shortblock casting $3963512 dated F-14-9 with repalcement #L2300 pistons. Block has 3/8 rods and nodulart cast iron crankshaft. Front pad was decked so no numbers on it and the pistons are about 10 to 1 for more of a steet use $3750.
1969 427-435HP 60 over block casting #3935439 dated F-14-8 stamped T1011LX 19S70738. Block was magged, cleaned, pressure tested and fitted with two sleeves, new cam bearings and freeze plugs ready to build $2500.
1969 427 4 bolt 60 over block casting #3963512 dated K-28-8 decked $2000.
1969 427 2 bolt engine complete from Holley 750 carb to pan with about 10,000 miles on it. Casting #3963512 dated I-6-9 with a set of square port 3964291 heads both dated K-8-9, hydralic camshaft, gm aftermarket aluminum intake. Very dependable motor $5000.
3946074 aluminum heads freshly rebuilt dated 6-12-69 & 6-13-69 $6000
3946074 aluminum heads freshly rebuilt dated 4-10-69 & 10-10-69 $4000
3946074 aluminum heads rebuilt dated 9-11-71 & 8-29-71 $3000
3946074 aluminum heads rebuilt dated 1-14-70 & 9-17-70 $3000
3933163 Aluminum intakes with dates of 9-24-68, 12-14-68, 4-30-69 & 6-17-69 $450 each.
3919840 square port heads both dated B-20-9 $1250
3919840 square port heads dated I-17-8 & I-30-8 $1250
3919840 square port singles dated F-18-8, G-31-8, J-29-8, C-27-9 & D-30-9 $600 each
6223 steel crank freshly turned 10 under $300
7/16 dimple rods $300
7/16 non dimple rods $100
1969 396-375HP rebuilt shortblock casting #3955272 dated H-9-8 decked. 11 to 1 factory pistons, step up camshaft and internals intact $2500.
1969 396-375HP standard bore block casting #3955272 dated A-21-9 stamped T0124JD. Block is very clean and should stay standard bore $1750.
330-770-2517 for any questions and pictures can be provided with an email address. Can ship if you cannot pick up.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
