Old 10-02-2013, 04:36 PM   #1
Billy Nees
Liked 7,909 Times in 1,754 Posts
Default Re: SRAC Meeting
Jeff, how about asking them to amend the "2014 Header Collector ruling" from "1" of stitch weld on each tube" to include "or minimum 2 fully welded tubes on each collector and tab and bolt on remaining slip-fit tubes". That should make it possible to remove the headers on some of these cars as welding all 4 tubes might make it not possible on some cars.
Billy Nees 1188 STK, SS
Old 10-02-2013, 06:01 PM   #2
Bob Bender
Bob Bender's Avatar
Liked 462 Times in 92 Posts
My headers tubes are bolted together with the straps and the collecters are bolted to the cross member. Have not got lose in 3 years.
Bob Bender 144 O/SA
Old 10-02-2013, 06:56 PM   #3
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
If collectors are bolted to cross member, would that satisfy requirement?
Bob Don 128 SS
Old 10-02-2013, 09:41 PM   #4
Doug Blackley
Doug Blackley's Avatar
And there's the X-pipe systems that are hung via a hanger set up to the car itself. Just consider how many things have to fail for a collector to come off that setup.
Doug Blackley 1697 STK
Old 10-03-2013, 02:55 AM   #5
SS Engine Guy
And please remember that some of us still try to squeeze out a little bit with primary extensions if required in certain situations. Also welding on some coatings will fail even when the surface is ground to clean metal. Embrittlement or something similar.
I'm not particularly fond of having a collector on a wire flopping around under my car possibly puncturing a front tire or severing a brake line or igniting my oil soaked engine diaper from sparks flying etc. etc.
SS Engine Guy is offline   Reply With Quote
Old 10-17-2013, 05:01 PM   #6
Jim Kaekel
Liked 536 Times in 110 Posts
Any news from SRAC meeting regarding rule changes?
Jim Kaekel 3836 STK
Old 10-17-2013, 10:07 PM   #7
Jeff Teuton
Liked 325 Times in 50 Posts
Basically not a lot of objection from the racers according to the members, just lots of objection to the price. I have a local source that can make those things. I'm going to send NHRA a set and get it approved. Will be cheap. How about Cajun Connectors for the Collectors? Nice ring.
Jeff Teuton 4022 STK
