Old 09-17-2013, 11:22 PM   #1
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Re: NHRA Tether Rule Update
Is there a possibility the NHRA's insurance company is requesting these after someone hearing of an accident or injury happening somewhere at some track?
I sure do understand if you can weld a roll bar, this would be a piece of cake to make. you guys have shown some nice designs on this thread.
chris ok is offline   Reply With Quote
Old 09-17-2013, 11:56 PM   #2
Bernie Cunningham
Liked 52 Times in 17 Posts
OK, it seems it ain't going away, (can't believe it made it this far, SHRA?) but I have got to get an answer with this question ---- ' if you have an approved tether system and somehow, somewhere, blackhole, planets aligned wrong or whatever and ya **** breaks free and does some damage i.e still hits somebody or something, WILL NHRA take responsibility cause they approved it??
how does that work when **** goes wrong in the oiler classes ? they must have more 'approved parts' then us ???
inquiring minds need to know!
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
Old 09-18-2013, 12:17 AM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs down Re: NHRA Tether Rule Update
A great question that needs to be answered! They still haven't answered why we can put in our own roll bar and submit them to tech but we are not capable of putting some clamps and cables on our headers and have them teched for approval! I disagree with you Jim Carter, this fact shouts kickback real loud! Jim
" The NHRA Technical Department will also accept a minimum ½” (half inch) stich weld located each primary tube as an alternative to the tethering system."
Don't insult our intelligence with this BS response! Weld my headers onto the car? Only a moron with no knowledge of race cars would suggest this!
Old 09-18-2013, 01:55 AM   #4
Jeff Lee
Jeff Lee's Avatar
And your suggesting that is not possible?
Jeff Lee 7494 D/S '70 AMX
Old 09-18-2013, 07:15 AM   #5
Exhausted
Exhausted's Avatar
Smile Re: NHRA Tether Rule Update
This is the craziest part of this rule. "stitch" welding collectors onto primary tubes, (which only a desperate idiot would do) is in no way a permanent solution. It is not a long amount of time before those welds will crack and is Not a solution at all.
They should also change the "bolt" ruling to say that each tube that goes into a collector have its own bolt and brackets, this would allow for differences with 421 type headers verses 4into1 headers. I understand the ruling is 4 bolts per collector, referring to a normal 4into1 collector?
I am not aware of any foolproof way of keeping headers intact besides a regular maintenance inspection of hardware as it is subject to intense vibration and will fail given enough time. NHRA guys are not going to get under every car and make sure that even their "bolted" retaining devices are still intact.
The whole thing is obviously a attempt to limit exposure to lawsuits and throw them off onto manufacturers instead of those organizations who don't or can't inspect cars they let run on their track or work to protect their "customers" from being hurt at their events.
Exhausted is offline   Reply With Quote
Old 09-18-2013, 07:53 AM   #6
Randall Klein
Liked 316 Times in 67 Posts
My Nomad has fender well headers, very obvious to tech, I'm curious how tech will go checking low-to-the-ground Colbalts, etc with headers tucked well under the frame.....our SS/MA '57 needs a trans blanket and never once has tech knelt down and looked.....I suppose some might be visible from engine compartment
Old 09-18-2013, 11:02 AM   #7
novassdude
Liked 136 Times in 49 Posts
Jim Please don't give NHRA any more ideas. Next you will have to take it to an NHRA accepted shop to have any work done on your car.
novassdude is offline   Reply With Quote
Old 09-18-2013, 12:06 PM   #8
Ed Wright
Ed Wright's Avatar
Jim, I have to wonder how you got "weld my headers onto the car" out if that?
Ed Wright 4156 SS/JA
Old 09-18-2013, 12:33 PM   #9
Jeff Lee
Jeff Lee's Avatar
Ed,
Many race cars require disassembly of the headers to get them on & off the car. Heck, you can't even change the starter on my car without taking the collector off and loosening the flange bolts up @ the head. Stitch weld them up and they are on the car until you take a sawzall to the headers!
Old 09-18-2013, 04:25 PM   #10
Ed Wright
Ed Wright's Avatar
Ok.
