Old 09-15-2013, 08:49 AM   #1
art leong
Default Re: New HP Numbers after Indy
Originally Posted by Nick Heath View Post
It seems that between Indy and Charlotte, we have a pretty good idea what the FSS combinations are capable of. If these cars were subject to the AHFS, would that be the case? Or would it be a parade of 1000' runs?
Is it possible that NHRA could use what they've learned to adjust rules for next year to make it more fair, and possibly make it a full time class?
How exactly do we use the AHFS to refactor a car that is not classified based on a HP-to-weight factor? Because they're running off of somewhat arbitrary weights, some combinations are lighter than their traditional Stock weight, and some are heavier.
The FSS rules are far from perfect and it's obvious that the indexes are on the generous side. I'm just thinking out loud here.
Very simple you factor the index. If you hit the index, the class competion stays the same noboby gets the advantage. It's done in superstock in the cubic inch to weight categories all the time. And in comp.
Art Leong 2095 SS
