Old 09-03-2013, 06:35 PM   #11
Stewart Way
Liked 70 Times in 22 Posts
Default Re: Heard in the Stands at the Indy
Carey
Looking at the picture you posted of the Funny Car, 2 things of note. There is a different rule for the space between the OD of the crank flange and the ID of the hole in the plate for a FC. FC has a limit of 7" max on the hole size, not the 1" difference. Can't tell what the ID is on the one in the photo. Second. if you look at the block plate/firewall it has a recessed area that the flywheel sits in that I think NHRA will likely tell you will be the solution to your problem. Think that piece has to be made by the same manuf as the shield. Just my thoughts and doesn't change the fact that you got hosed.
Like most, I can appreciate the effort you have put in and hope you stick with it. As an old tech man, I can tell you one of the hardest things was telling someone that just because you passed last week doesn't mean you did this week. Doesn't sound like telling you was all that hard for the official you ran into. Just wondering, if you has turned in a tech card, what would you have done about dates on the shield and clutch?
Stewart Way 2424 SS
