Old 08-19-2013, 01:20 PM   #1
DonatoEng
Liked 8 Times in 5 Posts
Default Re: DP rear axle assembly
The window control module will fail with a 16 volt system. You need to use a step down to feed the windows with 13v or less. If you eliminate the smart switch system you need to be sure to roll the window up after you get in the car or the glass will be on the outside of the seal. Not a pretty site at speed with the window pulling out.
PM me if you need window modules for the DP
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 08-19-2013, 02:51 PM   #2
denbreeden
denbreeden's Avatar
Liked 61 Times in 26 Posts
My windows have worked just fine for 3 years now on 16V, I replaced the factory switches and circuit board with dpdt switches,
Dennis Breeden
denbreeden is offline   Reply With Quote
Old 08-20-2013, 12:14 AM   #3
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
"destroying the integrity" just when was the integrity
Just stirring ..
Ron
