Old 08-05-2013, 10:36 PM   #1
Tim Lisson
Default Re: Bir s/ss pictures
Awesome photo's Lydia! I can't believe the quality out of that thingy you are using to take them.
I can hardly wait for the late September race. BIR's starting line crew is top notch! I don't believe it has been said on here but the starting line crew came up with a "system" to check with the racers. Basically a scorecard you share with the ticket gal on the starting line prep each pass. If there is something needing attention, she passes it on to the starting line crew and they stop, and fix it. What else can a racer ask for?
Tim
Tim Lisson is offline   Reply With Quote
Old 08-06-2013, 09:22 AM   #2
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Thumbs up Re: Bir s/ss pictures
Tim
You said it Tim!!
BIR was actually "asking the racer" how the traction was.
!!Amazing!!! W hen was the last time you seen that???
The track had incredible hook!!
Everything went perfect for both days of the S/SS COMBO!
What else could you want?
Thanks to the BIR staff for the help & making this as good as it can be!!!
Glen
MEXJOE is offline   Reply With Quote
