Old 07-30-2013, 11:21 PM   #18
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Generator Questions and Answers, by R&J Control Inc
Originally Posted by Sean Marconette View Post
Rob,
Does the generator sound like it has a load on it? Do you have access to a amp meter to measure the load at each circuit breaker? It sounds like there is a load on it from something else, other than what you have described. You could turn off circuit breakers one at a time and listen for the generator to unload, if something is drawing from it. I can run my A/C and everything in the trailer for close to 20hrs continuously on 15 gallons. I have a Onan Marquis Gold 7500.
Good Luck
Sean
I will try shutting off circuit breakers and see what happens. I got a meter and will try that too. I figured it was just a fuel pig untill I started talking to another guy with the same generator. Does not seem to act like its under load but if its had a problem since new maybe I just never noticed and thought it sounded normal. Thanks for the help.
